On the Ambari Server host, install the appropriate JDBC .jar file.
Download the Oracle JDBC (OJDBC) driver from http://www.oracle.com/technetwork/database/features/jdbc/index-091264.html.
Select
Oracle Database 11g Release 2 - ojdbc6.jar
.Copy the .jar file to the Java share directory.
cp ojdbc6.jar /usr/share/java
Make sure the .jar file has the appropriate permissions - 644.
Create a user for Ambari and grant it permissions.
Using the Oracle database admin utility:
# sqlplus sys/root as sysdba CREATE USER $AMBARIUSER IDENTIFIED BY $AMBARIPASSWORD default tablespace “USERS” temporary tablespace “TEMP”; GRANT unlimited tablespace to $AMBARIUSER; GRANT create session to $AMBARIUSER; GRANT create TABLE to $AMBARIUSER; QUIT;
Where
$AMBARIUSER
is the Ambari user name and$AMBARIPASSWORD
is the Ambari user password.
You must pre-load the Ambari database schema into your Oracle database using the schema script.
sqlplus $AMBARIUSER/$AMBARIPASSWORD < Ambari-DDL-Oracle-CREATE.sql
Find the Ambari-DDL-Oracle-CREATE.sql file in the
/var/lib/ambari-server/resources/
Advanced Database Configuration > Option [2] Oracle
and enter the information use the username/password credentials you created in step 2.
