Ambari Reference Guide
Write Custom Java to Create LZO Files
  1. Create text files as the output of the Hive query.
  2. Write custom Java code to
    • convert Hive query generated text files to .lzo files
    • generate lzo.index files for the .lzo files
Hive Query Parameters
Prefix the query string with these parameters:
SET hive.exec.compress.output=false
SET mapreduce.output.fileoutputformat.compress=false
For example:
hive -e "SET hive.exec.compress.output=false;SET mapreduce.output.fileoutputformat.compress=false;<query-string>"
