As an alternative to using the CCP Management user interface to map fields to HBase
enrichment, you can use the CLI.
- Edit the new data source enrichment configuration at
$METRON_HOME/config/zookeeper/enrichments/$DATASOURCE to associate
the ip_src_addr with the user enrichment:
"index" : "squid",
"batchSize" : 1,
"enrichment" : {
"fieldMap" : {
"hbaseEnrichment" : [ "ip_src_addr" ]
"fieldToTypeMap" : {
"ip_src_addr" : [ "whois" ]
"config" : { }
"threatIntel" : {
"fieldMap" : { },
"fieldToTypeMap" : { },
"config" : { },
"triageConfig" : {
"riskLevelRules" : { },
"aggregator" : "MAX",
"aggregationConfig" : { }
"configuration" : { }
- Push this configuration to ZooKeeper:
$METRON_HOME/bin/zk_load_configs.sh -m PUSH -z $ZOOKEEPER_HOST:2181 -i $METRON_HOME/zookeeper
After you finish enriching telemetry events, you should ensure that the enriched data
is displaying on the Metron dashboard.
