Installing Knox
You can install Knox for Cloudera Cybersecurity Platform (CCP) with Ambari. The Knox service option is available through the Add Service wizard after CCP is installed.
Login to Ambari at
http://$AMBARI_HOST:8080. - In the left navigation menu, click Actions, then select Add Service.
- On the Add Service Wizard page, select Knox, then click Next.
- You are prompted to Assign Masters. Make a note of the Knox Gateway host(s) for use in subsequent installation steps. Click Next.
- Enter a password in the Knox Master Secret field, then click Next.
- Confirm the Ambari recommended changes for your dependent configuration, then click OK.
- Click Deploy.
