Changing the Metron Dashboard Background Color
You can choose to view the Metron dashboard with either a light or dark background. The dark background is sometimes preferred in a dimly lit security operations center.
  1. Click (Gear icon) in the top right of the Metron dashboard.
    You should see a check box next to Use dark theme near the top of the dashboard.
  2. Select the check box to use the dark theme for the dashboard.
    To return to the light theme, clear the check box.
