Securing ZooKeeper with TLS
As discussed above, communications with ZooKeeper are insecure by default. The second option for securely authenticating to and communicating with ZooKeeper is to use certificate-based authentication with a TLS-enabled ZooKeeper server (available since ZooKeeper's 3.5.x releases). Instructions for enabling TLS on an external ZooKeeper ensemble can be found in the https://zookeeper.apache.org/doc/r3.5.5/zookeeperAdmin.html#sc_authOptions.
Once you have a TLS-enabled instance of ZooKeeper, TLS can be enabled for the NiFi client by setting nifi.zookeeper.client.secure=true
. By default, the ZooKeeper client will use the existing nifi.security.*
properties for the keystore and truststore. If you require separate TLS configuration for ZooKeeper, you can create a separate keystore and truststore and configure the following properties in the $NIFI_HOME/conf/nifi.properties file:
Property Name | Description | Default |
Whether to acccess ZooKeeper using client TLS. |
false |
Filename of the Keystore containing the private key to use when communicating with ZooKeeper. |
none |
Optional. The type of the Keystore. Must be |
none |
The password for the Keystore. |
none |
Filename of the Truststore that will be used to verify the ZooKeeper server(s). |
none |
Optional. The type of the Truststore. Must be |
none |
The password for the Truststore. |
none |
Whether using the default security properties or the ZooKeeper specific properties, the keystore and truststores must contain the appropriate keys and certificates for use with ZooKeeper (i.e., the keys and certificates need to align with the ZooKeeper configuration either way). NiFi's TLS Toolkit can be used to help generate the keystore and truststore used for ZooKeeper client/server access.
After updating the above properties and starting NiFi, network communication with ZooKeeper will be secure and ZooKeeper will now use the NiFi node's certificate principal when authenticating access. This will be reflected in log messages like the following on the ZooKeeper server:
2020-02-24 23:37:52,671 [myid:2] - INFO [nioEventLoopGroup-4-1:X509AuthenticationProvider@172] - Authenticated Id 'CN=nifi-node1,OU=NIFI' for Scheme 'x509'
ZooKeeper uses Netty to support network encryption and certificate-based authentication. When TLS is enabled, both the ZooKeeper server and its clients must be configured to use Netty-based connections instead of the default NIO implementations. This is configured automatically for NiFi when nifi.zookeeper.client.secure
is set to true. Once Netty is enabled, you should see log messages like the following in $NIFI_HOME/logs/nifi-app.log:
2020-02-24 23:37:54,082 INFO [nioEventLoopGroup-3-1] o.apache.zookeeper.ClientCnxnSocketNetty SSL handler added for channel: [id: 0xa831f9c3]
2020-02-24 23:37:54,104 INFO [nioEventLoopGroup-3-1] o.apache.zookeeper.ClientCnxnSocketNetty channel is connected: [id: 0xa831f9c3, L:/172.17.0.4:56510 - R:8e38869cd1d1/172.17.0.3:2281]
