Migrating Between Source and Destination ZooKeepers
Before you begin, confirm that:
  • You have installed the destination ZooKeeper cluster.
  • You have installed and configured a NiFi cluster to use the destination ZooKeeper cluster.
  • If you are migrating ZooKeepers due to upgrading NiFi from 0.x to 1.x,, you have already followed appropriate NiFi upgrade steps.
  • You have configured Kerberos as needed.
  • You have not started processing any dataflow (to avoid duplicate data processing).
  • If one of the ZooKeeper clusters you are using is configured with Kerberos, you are running the ZooKeeper Migrator from a host that has access to NiFi's ZooKeeper client jaas configuration file.
