Unsupported Flow Management features
Some Flow Management features exist in Cloudera DataFlow for Data Hub, but are not supported by Cloudera.
7.3.1.400
There are no unsupported features in this release.
7.3.1.0
- NiFi 1.28.1
- NiFi 2.0.0
The following Flow Management technical preview features are available in Cloudera DataFlow for Data Hub 7.3.1.0. These features are not ready for production use. Cloudera encourages you to explore these technical preview features in non-production environments and share your feedback through the Cloudera Community Forums.
- The Flow Analysis Rules engine is in Technical Preview, including all provided rules.
- The Python API feature is in Technical Preview, along with all Python extensions that use this API.
- The ability to run a Process Group using the Stateless Engine is in Technical Preview.
- NiFi Registry
