Known issues in Cloudera Flow Management
Review the list of known issues and limitations in Cloudera DataFlow for Data Hub 4.12.0.
Kafka OAuth authentication not supported across mixed Kafka component groups
Kafka OAuth2 (OAUTHBEARER) authentication cannot be used simultaneously by components from Kafka_2_6 / Kafka2CDP and Kafka3ConnectionService. If OAuth is enabled for one group, components in the other group will fail with authentication errors.
Use OAuth authentication with only one Kafka component group in a deployment, or restart before switching between them..
