Unsupported Flow Management features
Review the list of features that are not supported in Cloudera DataFlow for Data Hub.
The following features are developed and tested by the Cloudera community but are not officially supported by Cloudera. These features are excluded for a variety of reasons, including insufficient reliability or incomplete test case coverage, declaration of non-production readiness by the community at large, and feature deviation from Cloudera best practices. Do not use these features in your production environments.
Unsupported NiFi components
NiFi 1 custom NARs cannot be successfully loaded into NiFi 2. If your NiFi setup includes custom NARs, it is a requirement to update your dependencies to align with NiFi 2. This entails making the necessary adjustments and rebuilding your NARs using Java 21. The below components are not supported and should not be used anymore.
Processors
- AttributeRollingWindow
- ConsumeIMAP
- ConsumePOP3
- DebugFlow
- DeleteMongo
- ExecuteSparkInteractive
- ExtractDocumentText
- ExtractEmailAttachments
- ExtractEmailHeaders
- ExtractMediaMetadata
- ExtractTNEFAttachments
- GetDynamoDB
- GetHDFSEvents
- GetMongo
- GetSmbFile
- ISPEnrichIP
- ListenSMTP
- ModifyBytes
- ParseNetflowv5
- ParseSyslog5424
- PutIcebergRecord
- PutIoTDBRecord
- PutMongo
- QueryAzureDataExplorer
- QueryDNS
- QueryIoTDBRecord
- RunMongoAggregation
Controller services
- HikariCPConnectionPool
- JettyWebSocketClient
- JettyWebSocketServer
- LivySessionController
- SimpleCsvFileLookupService
- StandardKustoQueryService
- XMLFileLookupService
Reporting tasks
- AzureLogAnalyticsProvenanceReportingTask
- AzureLogAnalyticsReportingTask
- DataDogReportingTask
- StandardGangliaReporte
