Querying the engine type
You can query whether a project is configured using ML Runtimes or Legacy Engine.
To determine if a project is configured to use either ML Runtimes or Legacy Engines, use the cdswctl projects getEngineType command and specify the project with the -p parameter.
For example, to determine if configured to use ML Runtimes:
cdswctl projects getEngineType -p demouser/runtimeproject
ml_runtime
cdswctl projects getEngineType -p demouser/legacyproject
legacy_engine
