Project Admins: Enable the CUDA Engine for your Project
Project administrators can use the following steps to make it the CUDA engine the default engine used for workloads within a particular project.
- Navigate to your project's Overview page.
 - Click Settings.
 - Go to the Engines tab.
 - Under Engine Image, select the CUDA-capable engine image from the dropdown.
