Test the CUDA Engine
You can use the following simple examples to test whether the new CUDA engine is able to leverage GPUs as expected.
- Go to a project that is using the CUDA engine and click New Session.
 - Launch a new session with GPUs.
            Run the following command in the workbench command prompt to verify that the driver
               was installed correctly:
! /usr/bin/nvidia-smi -
            Use any of the following code samples to confirm that the new engine works with
               common deep learning libraries.
            Pytorch
!pip3 install torch from torch import cuda assert cuda.is_available() assert cuda.device_count() > 0 print(cuda.get_device_name(cuda.current_device()))Tensorflow!pip3 install tensorflow-gpu==2.0.0 from tensorflow.python.client import device_lib assert 'GPU' in str(device_lib.list_local_devices()) device_lib.list_local_devices()Keras!pip3 install keras from keras import backend assert len(backend.tensorflow_backend._get_available_gpus()) > 0 print(backend.tensorflow_backend._get_available_gpus())
