After you add processors and other components to the canvas of the Edge Flow Manager
(EFM) UIand configure them, the next step is to connect them to one another. This is
accomplished by creating a connection between each component.
Hover the mouse over a component.
An arrow appears as shown in the following image:
Drag the arrow from one component to another until the second component is
highlighted, then release the mouse.
A Create Connection dialog appears as shown in the
following image:
The dialog allows you to choose the Source Relationship
that must be included in the connection. At least one relationship must be
selected. If only one relationship is available, it is automatically
selected.
