Setting agent parameter values in Cloudera Edge Management
Learn about parameter context and how to set agent parameter values in Cloudera Edge Management.
Any collection of replacement key-value pairs is known as a parameter context. Parameters never
exist on their own. They only exist in a parameter context. Edge Flow Manager
allows setting parameter contexts at the following levels:
| Levels | Description |
| Agent Class | An agent class level parameter context, if present, overwrites the flow level context. This is to support multiple versions of a flow definition to an agent class, but allowing agent class configuration values that override whatever is set in the Flow Designer UI as default values. Agent class level parameter contexts are set using the Edge Flow Manager REST API, and can be set once to impact all future flows published to that agent class. |
| Agent | An agent level parameter context, if present, overwrites the agent class and flow level contexts. This is to support deploying a flow to multiple agents in an agent class but allowing per-agent configuration values. Agent level parameter contexts are set using the Edge Flow Manager REST API, and can be set once to affect all future flows deployed to that agent. |
Resolving parameter contexts
When an agent requests a flow from Edge Flow Manager, it substitutes
parameter values just-in-time for placeholders by resolving parameter values in this
hierarchy of contexts. In order to accomplish this, the flow URI that Edge Flow Manager sends to agents as part of a flow update operation looks
like the following:
GET /efm/api/flows/{flowId}?aid={agentId}When a flow is fetched, the agent, agent class, and flow level parameter contexts are retrieved and applied to the flow in the hierarchy listed above.
REST API endpoints for parameters
For information about creating parameter contexts and mapping them to flows, agent classes,
and agents, see the following:
- Parameters section in Edge Flow Manager REST API.
- Parameter Mappings section in Edge Flow Manager REST API.
For tutorials of specific use cases that leverage this feature, including examples interacting
with the REST API using curl, see Using Agent Parameters.
