Using Cloudera Edge ManagementPDF version
Managing flow versions in Cloudera Edge Management
Learn how to undo and redo changes in your draft dataflows, view and load published flow versions, and switch between versioned flows using the Cloudera Edge Management UI in Cloudera Edge Management.
You can undo changes in the Cloudera Edge Management Flow Designer made after the last publish event, allowing you to revert accidental edits. Similarly, you can redo changes that were previously reverted.
  1. Locate the Undo/Redo icons at the bottom right corner of the Flow Designer.
  2. Click to revert changes made since the last flow publish event, or click to reapply changes that were previously undone.
You can view and load previously published flow versions in the Cloudera Edge Management Flow Designer.
  1. View published flow versions.
    1. Open the right-side navigation pane when no component is selected.
    2. Review the list of previously published versions.
      Each entry includes basic information like the publish date, publisher, and any comments added while publishing the flow.
  2. Load a previous flow version.
    1. In the right-side navigation pane, find the version you want to load.
    2. Click the Load into flow designer option on the selected line.
      This action replaces the current flow and parameters in the designer with the selected version.
