Using separate ports in Edge Flow Manager
You can make Edge Flow Manager listen to separate ports for UI and C2
  type of requests. To do so, you need to uncomment the #efm.server.c2Port=
  property in the efm.properties file, and set a valid port number as the value of
  the #efm.server.c2Port= property.
The Edge Flow Manager REST API can be divided into two logical
     parts. The first group comprises the REST endpoints which are used by the users to create
     flows, manage credentials, and so on through the UI, called UI endpoints. The second group
     comprises the REST endpoints which are used by the MiNiFi agent to communicate with Edge Flow Manager, called C2 endpoints. With the default configuration, Edge Flow Manager listens to port configured with the
      efm.server.port property for all kinds of requests.
There could be cases where distinction between the UI and C2 traffic needs to be made on the network level.
A property is introduced in the efm.properties file to enable
     separate UI and C2 communication.
#efm.server.c2Port=
    By default it is commented out so Edge Flow Manager listens to the
     port set with the efm.server.port property.
efm.server.c2Port property and set a
     valid port number.
