Embedded ZooKeeper with TLS
A NiFi cluster can be deployed using a ZooKeeper instance(s) embedded in NiFi itself which all nodes can communicate with. As of NiFi 1.13.0, communication between nodes and this embedded ZooKeeper can now be secured with TLS. Versions of NiFi prior to 1.13 did not use secure client access with embedded ZooKeeper(s). The configuration for the client side of the connection will operate in the same way as an external ZooKeeper. That is, it will use the nifi.security.* properties from the nifi.properties file by default, unless you specifiy explicit ZooKeeper keystore/truststore properties with nifi.zookeeper.security.* as described above.
The server configuration will operate in the same way as an insecure embedded server, but with the secureClientPort set (typically port 2281).
Example $NIFI_HOME/conf/zookeeper.properties file:
secureClientPort=2281
initLimit=10
autopurge.purgeInterval=24
syncLimit=5
tickTime=2000
dataDir=./state/zookeeper
autopurge.snapRetainCount=30
server.1=nifi1.example.com:2888:3888
server.2=nifi2.example.com:2888:3888
server.3=nifi3.example.com:2888:3888
When used with a three node NiFi cluster, the above configuration file would establish a three node ZooKeeper quorum with each node listening on secure port 2281 for client connections with NiFi, 2888 for quorum communication and 3888 for leader election.
The following is an example of the relevant properties to set in $NIFI_HOME/conf/nifi.properties to run and connect to this quorum:
nifi.security.keystore=./conf/keystore.jks
nifi.security.keystoreType=jks
nifi.security.keystorePasswd=password
nifi.security.keyPasswd=password
nifi.security.truststore=./conf/truststore.jks
nifi.security.truststoreType=jks
nifi.security.truststorePasswd=password
nifi.security.user.authorizer=managed-authorizer
nifi.zookeeper.connect.string=nifi1.example.com:2281,nifi2.example.com:2281,nifi3.example.com:2281
nifi.zookeeper.connect.timeout=10 secs
nifi.zookeeper.session.timeout=10 secs
nifi.zookeeper.root.node=/nifi
nifi.zookeeper.client.secure=true
nifi.state.management.embedded.zookeeper.start=true
nifi.state.management.embedded.zookeeper.properties=./conf/zookeeper.properties
nifi.state.management.configuration.file=./conf/state-management.xml
nifi.state.management.provider.cluster=zk-provider
