Using Flow Library Registry ClientPDF version
Adding Cloudera Flow Library Registry Client
The Cloudera Flow Library Registry Client provides access to to Cloudera's exclusive Flow Library. These predefined flows can help you swiftly deploy solutions tailored to your specific needs in a wide range of use cases. Learn how to configure the Registry Client and check out flows from the library.
  1. Open the NiFi UI.
  2. Click the Global menu and select Controller Settings.
  3. Switch to the Registry Clients tab.
  4. Add a new client.
    1. Select the type and give it a name.
    2. Configure the client.
      You will have to create a StandardWebClientServiceProvider controller service and start it with its default configuration.
You can now start using the new client to check out flows from the Cloudera Flow Library.
