Checking out a flow
Learn how to check out a data flow from the Cloudera Flow Library.
Drag and drop a process group onto the canvas and click Import from
Registry.
In the drop-down list, select the Registry Client configured to access the Flow
Library.
Select the desired bucket.
Select the flow that you want to check out in NiFi by clicking the selected
version and then clicking Import.
- Optional:
All flows stored in the Cloudera Flow Library are read-only so you are not able
to change the original flow that you have checked out.
If you want to edit the flow, you can create your own version:
Right-click the process group, select Version
and click Stop version control.
- Make the changes you want.
- Version your new flow as a custom flow using another Registry Client into another Registry (NiFi Registry or Cloudera Data Flow Catalog): right-click the process group, select Version, and click Start version control.
