Choosing default engine
This topic describes how to choose a default engine for creating projects.
Required Role: MLAdmin
Make sure you are assigned the MLAdmin role in Cloudera. Only users with the MLAdmin role will be logged into Cloudera AI Workbenches with Site Administrator privileges.
There are two types of default engines: ML Runtimes and Legacy Engines. However, legacy engines are deprecated in the current release and project settings default to ML Runtime.
Legacy engines Engines contain the machinery necessary to run sessions using all four interpreter options that Cloudera AI currently supports (Python 2, Python 3, R and Scala) and other support utilities (C and Fortran compilers, LaTeX, etc.). ML Runtimes are thinner and more lightweight than legacy engines. Rather than supporting multiple programming languages in a single engine, each Runtime variant supports a single interpreter version and a subset of utilities and libraries to run the user’s code in Sessions, Jobs, Experiments, Models, or Applications.
  1. Select Apps in the left navigation pane on the Anywhere Cloud Console.
  2. Search for the required Cloudera AI Workbench instance.
    Ensure that the status of the instance is Deployed.
  3. Click on the name of the required instance.
    A pane opens displaying the available information for the selected instance.
  4. Click the URL of the selected Cloudera AI Workbench instance.
    The Cloudera AI Workbench home page is displayed.
  5. Click Site Administration > Runtimes.
  6. Choose the Default Engine you would like to use as the default for all newly created projects in this workbench.
  7. Modify the remaining information on the page:
    • Resource Profiles listed in the table are selectable resource options for both legacy Engines and ML Runtime (for example, when starting a Session or Job)
    • The remaining information on the page applies to site-level settings specific for legacy Engines.
