Configure sizing and scaling
Set the size and number of Apache NiFi nodes, auto-scaling, and the type of storage to be used.
Specify NiFi node size by selecting one of the options:
- Extra Small: 2 vCores per Node, 4 GB RAM per Node
- Small: 3 vCores per Node, 6 GB RAM per Node
- Medium: 6 vCores per Node, 12 GB RAM per Node
- Large: 12 vCores per Node, 24 GB RAM per Node
Set the number of NiFi nodes and auto-scaling.
- Select the Auto Scaling checkbox, if you want
your cluster to automatically scale based on CPU utilization. When you
enable auto-scaling, the minimum number of NiFi nodes are used for
initial size and the workload scales up or down depending on resource
demands.
Set the number of nodes between 1 and 32.
Use the slider or text fields to adjust the minimum and maximum number of nodes. Cloudera Data Flow automatically determines the optimal number of nodes within the specified boundaries.
- If you enabled Auto Scaling, you may enable your
flow to scale based on flow performance metrics. To do so, select the
Flow Metrics Scaling checkbox.
demands.
Select storage type.
Select whether you want your deployment to use storage optimized for cost or for performance.
- Standard: 512 GB Content Repo Size, 512 GB Provenance Repo Size, 256 GB Flow File Repo Size
- Saver: 64 GB Content Repo Size, 64 GB Provenance Repo Size, 64 GB Flow File Repo Size
If applicable, configure additional storage for Python processors.
The wizard automatically detects if the flow definition being deployed contains any Python processors and suggests the amount of extra disk space to add because of them.
Click Next
