You can select a group of parameters and make them available for reuse by exporting
them as a parameter group.
When you want to share a group of parameters for reuse,
use the Export Parameter Group option. This allows for the reuse
of those parameters without the need for copying and pasting them
individually.
On the Flow Design canvas, select .
Select the All Parameters tab and click
Export
Parameter Group.
The Export to a Shared Parameter Group modal opens.
Provide a Parameter Group Name. The name must be unique
within a workspace, Cloudera Data Flow automatically
validates the name.
- Optional:
Provide a Description of the parameter group.
Select Parameters to export by checking the boxes next
to them. Select the checkbox on top to select all parameters.
- Optional:
If you select the Import this Shared Group checkbox, the
newly created shared parameter group will be automatically imported to the draft
from which the parameters were originally exported, as the parameter group with
the highest priority. Draft parameters with matching names will be replaced with
parameters in the shared parameter group.
Click Export.
