You can import existing parameter groups into your flow draft so you do not have to
individually copy and paste values that are common in an environment, such as credentials or
access paths.
One use case is to import a parameter group that was
created earlier to reuse it in your draft. This is useful, for example, to share
credentials, access paths, and so on between several flows within a project. Another use
case is exporting draft parameters as a parameter group from the flow draft you are
working on, then immediately importing the same group back to your draft to replace
flow-specific draft parameters with ones that can be shared and reused.
On the Flow Designer canvas, select .
Select the Parameter Groups tab and click
Import Shared
Parameter Group.
The Import Parameter Group modal opens.
From the Select Parameter Group drop-down select the
group you want to import.
- Optional:
Select the Remove overlapping draft parameters
checkbox.
This is good practice, because draft parameters always take precedence over
parameters in an imported parameter group.
Click Import.
To finalize the changes you made, click
Apply Changes.
