Creating a draft from a ReadyFlow
You can use ReadyFlows as the starting point of your flow design. Select an available ReadyFlow from the ReadyFlow Gallery, open it for editing on the Canvas, and publish it to the Catalog as your own custom flow definition.
ReadyFlows are read-only, therefore you cannot add a new version to them. When you are done with creating your customized version of the given ReadyFlow, you can only publish your work to the Catalog as a new flow definition.
  1. Select ReadyFlow Gallery in the left navigation pane.
  2. Select the ReadyFlow you want to use as a template for your flow design.
  3. Click Create New Draft.
  4. Provide a valid Draft Name.
    Flow names must be unique. If a draft with the provided name already exists, you need to provide a different name.
  5. Click Create.
    The selected ReadyFlow opens as a draft with the Draft Name you provided, on the Flow Design canvas.
