Adding a parameter to your draft
The values of properties in the flow, including sensitive properties, can be parameterized. Learn how to add a parameter to your draft.
- You have created a draft in Cloudera Data Flow Flow Designer.
Adding a parameter from Flow Options
Learn about creating parameters from the Flow Options menu.
Converting a property to a parameter from the Configuration pane
Learn about converting a property of a component into a parameter from the Configuration pane.
