Open the Hello World ReadyFlow as a template for your draft
Learn how to create the Hello World ReadyFlow as a starting point for your custom flow in the Flow Designer.
ReadyFlows are read-only, therefore you cannot publish a new version of them. When you are done with creating your customized version of the given ReadyFlow, you can publish your work to the Catalog only as a new flow definition.
  1. Select the ReadyFlow Gallery item in the left navigation pane.
  2. In the [Search] field, start typing 'Hello World'.
    Filtering for a ReadyFlow
  3. Click the Create New Draft button.
  4. Provide a valid name in the Draft Name field for the draft flow.
    Flow names must be unique. If a draft with the provided name already exists, you must provide a different name.
  5. Click the Create button.
    Hello World opens as a draft in the designated Flow Designer workspace with the Draft Name you provided on the Flow Design canvas.
Proceed with creating the necessary Controller Services.
