The Flow Designer canvas
Learn about getting around and performing basic actions on the Flow Design Canvas.
Components sidebar
You can add components to your draft by dragging them from the Components sidebar and dropping them onto the Canvas.
Configuration pane
To access the Configuration pane, click
Expand in the upper-right corner of the workspace. The
Configuration pane is context-sensitive. It always displays the
settings belonging to the element selected on the Canvas. When you
create a new draft and the Canvas is empty, it defaults to the
Process Group that was auto-created with the draft.
To hide the Configuration pane, click
Hide.
Flow Options
Flow Options provides the following additional configuration options:
- Adding, deleting, and configuring controller services.
- Adding, deleting, and editing parameters, exporting parameters as shared parameter groups.
- Importing, and deleting shared parameter groups.
- Accessing the NiFi component documentation.
- Viewing data provenance for an active test session.
- Downloading logs for a test session.
- Managing test sessions.
- Publishing drafts to the Catalog as flow definitions.
