Deleting a flow draft
Learn about deleting flow drafts.
  • Make sure that you have the cdf-admin or cdf-flow-admin permission to perform this task.
  1. From the Cloudera Data Flow navigation pane select Flow Design.
  2. Select the Flow draft that you want to delete.
  3. Click [Options] > Delete.
  4. Click Delete to confirm your choice.
