Create a new flow
Create and name a new flow in Flow Designer.
Open Cloudera Data Flow from the
Home view, by clicking Data Applications > Data Flow > Navigate to Instance
and selecting your Cloudera Data Flow instance.
Click
Flow Design in the left navigation pane.
You are redirected to the Flow Drafts view, where previously created drafts are displayed, one flow per row.
Click the
Create Draft button.
Provide a Draft Name.
For example, provide Hello World.
Click the Create button.
Flow Designer creates a default Process Group with the Draft Name you provided, Hello World in this case, and you are redirected to the Flow Design canvas. The Configuration pane on the right displays configuration options for the default Process Group.
