Swap the controller services in your draft
Customize your draft by replacing services to change the destination file format.
  1. On the Flow Designer canvas select the Convert JSON TO AVRO processor by clicking on it.
  2. In the Configuration pane scroll down to the Properties section, click the icon next to the Record Writer property and select the CSVRecordSetWriter_Recent_Changes service from the dropdown list.
  3. Click the OK button.
  4. In the Settings section, rename the processor from Convert JSON to AVRO to Convert JSON to CSV.
  5. Click the Apply button.
  6. On the Flow Designer canvas select the Filter Edits processor by clicking on it.
  7. In the Configuration pane scroll down to the Properties option, click the Link[Link] icon next to the Record Reader property and select the CSVReader_Recent_Changes service from the dropdown list.
  8. Click the OK button.
  9. Click the Link[Link] icon next to Record Writer property and select the CSVRecordSetWriter_Recent_Changes service from the dropdown list.
  10. Click the OK button.
  11. Click the Apply button.
  12. Proceed with updating the remaining Record Reader and Record Writer references.
    You must modify the configurations of the Route on Content Size and the two Merge Edit Events processors.
  13. Check that you have updated all the processors.
    1. Go to Flow Options > Services.
    2. Select the CSVReader_Recent_Changes service and check the Referencing Components section.
      Check if you see the following components:
      • Filter Edits
      • Merge Edit Events
      • Merge Edit Events
      • Route On Content Size
    3. Select the CSVRecordSetWriter_Recent_Changes service and check the Referencing Components section.
      • Convert JSON to CSV
      • Filter Edits
      • Merge Edit Events
      • Merge Edit Events
    4. If you check the AvroReader_Recent_Changes and AvroWriter_Recent_Changes services, you are expected to see the No referencing Processors to display. text.
  14. Delete the AvroReader_Recent_Changes and AvroWriter_Recent_Changes services by selecting the service and clicking the Delete icon.
    In the confirmation pop-up click the Delete button.
  15. Return to the flow design canvas.
Start a Test Session to validate your draft.
