To validate your draft start a test session, provisioning a NiFi cluster.
You must have the cdf-flow-admin role assigned to you to perform this task
For more information, see Cloudera Data Flow user
roles.
You have created a draft in Flow Designer.
Initiate a test session by clicking the To fully validate your flow
and develop with live data, start a test session. banner.
Pick a NiFi Runtime Version for your deployment.
By default, the latest available version is selected. If you need a different
version, click Change Version and select your preferred
version from the drop-down, then click Apply.
Specify NiFi node size by selecting one of the options:
Extra Small: 2 vCores per Node, 4 GB RAM per
Node
Small: 3 vCores per Node, 6 GB RAM per Node
Medium: 6 vCores per Node, 12 GB RAM per
Node
Large: 12 vCores per Node, 24 GB RAM per
Node
Click Start Test Session.
Commissioning of the NiFi cluster initiates and test session status
changes to Starting Test
Session...
Wait for the status to change to Active Test
Session.
