When you run a test session and need to verify how data is being processed, you can
use the List Queue view to inspect flow files at any connection in your flow. Viewing
queued flow files and their attributes helps you confirm that processors are producing the
expected output before you publish your flow.
You must have the cdf-flow-admin role assigned to you to perform this task
For more information, see Cloudera Data Flow user
roles.
You have an active test session.
On the Flow Designer canvas, click the connection where
you want to inspect the flow files.
In the Configuration pane select [Options] > List Queue.
In the List Queue view, All Queued
Flow Files for [***RELATIONSHIP NAME***]
Relationship opens.
Select a flow file by clicking it to view its Attributes
in the right-hand pane.
Optional: If there is an attribute that is of special interest to you, hover the cursor
over it and select Pin this
attribute.
The selected attribute is pinned to the top of the list of attributes.
Pinning persists, if you select a different flow file, or return to the Canvas
and decide to view flow files later, you will find the pinned attribute(s) at
the top of the list.
To view flow file content, click Open in Data
Viewer on top of the Attributes pane.
The contents of the flow file is displayed in a new tab in your
browser.
