Troubleshooting test sessions
When your Flow Designer test session shows bad health or other issues, you can use the download logs feature and the guidance in this topic to investigate the cause. Understanding common test session problems helps you resolve them quickly and continue developing your data flows.
Test session status changes to 'Bad Health'
The status of a test session changes to bad health .
Select to investigate the possible cause.
