Key performance indicators
You can use key performance indicators (KPIs) to monitor critical parts of your Apache NiFi deployments on the central monitoring dashboard. You do not need to drill deep into the NiFi data flow and find the metric to monitor it in NiFi. You can also choose to create alerts for your KPIs in Cloudera Data Flow.
Apache NiFi has multiple metrics to monitor for the system such as memory usage, CPU usage, data flow statistics and so on. KPIs are representations of those metrics for a NiFi component in Cloudera Data Flow.
You can set alerts while configuring KPIs in your deployment. If you set an alert for a KPI scope and metric combination, you get alerted if your flow definition meets the conditions set in that alert.
In the above image, a KPI is set for the All Flows KPI scope and Data In metric combination. When the data into the entire flow exceeds the 1MB boundary for 10 seconds, an alert is created.
