ADLS to ADLS Avro required parameters
When deploying the ADLS to ADLS Avro ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| ADLS Storage Account Key | Specify the ADLS storage account key used to access the source and destination locations. |
| ADLS Storage Account Name | Specify the ADLS storage account name used to access the source and destination locations. |
| AWS Access Key ID | Specify the AWS access key ID. |
| AWS Region | Specify the AWS region in which your schema was created. |
| AWS Secret Access Key | Specify the AWS secret access key. |
| CSV Delimiter | If your source data is CSV, specify the delimiter here. The default value is
| Data Input Format | Specify the format of your input data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow. |
| Destination ADLS File System | Specify the name of the destination ADLS file system also known as container. |
| Destination ADLS Path | Specify the name of the destination ADLS path you want to write to. The full path is constructed from: abfs://#{Destination ADLS File System}@#{ADLS Storage Account
Name}.dfs.core.windows.net/#{Destination ADLS Path} |
| Schema Name | Specify the schema name to be looked up in the Schema Registry. |
| Schema Registry Name | Specify the name of the Schema Registry you want to connect to. |
| Source ADLS File System | Specify the name of the source ADLS file system also known as container. |
| Source ADLS Path | Specify the name of the ADLS path you want to read from. The full path is constructed from: abfs://#{Source ADLS File System}@#{ADLS Storage Account
Name}.dfs.core.windows.net/#{Source ADLS Path} |
