ADLS to Milvus required parameters
When deploying the ADLS to Milvus ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
Table 1. ADLS to Milvus ReadyFlow configuration parameters
Parameter Name Description
HuggingFace Embedding Model Specify the HuggingFace model name to use for embedding the data.
The default model is 'all-MiniLM-L12-v2'.
Milvus Access Token Specify the access token for the destination Milvus instance.
Milvus Collection Name Specify the name of the destination Milvus collection.
Milvus Instance URI Specify the URI of the destination Milvus instance.
Source ADLS File System Specify the name of the source ADLS file system also known as container.
Source ADLS Path Specify the path within the source container where you want to read from.
Source ADLS Storage Account Specify the source ADLS storage account name.
Source ADLS Storage Account Key Specify the source ADLS storage account key.
