ADLS to OpenSearch required parameters
When deploying the ADLS to OpenSearch ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| OpenAI API Key | Specify the API key used to authenticate to OpenAI. |
| OpenAI Model Name | Specify the OpenAI model name to use for embedding the data.
The default model is 'text-embedding-ada-002'. |
| OpenSearch Document Text Field | The name of the field in the OpenSearch document where the text is stored. The default value is `text`. |
| OpenSearch Document Vector Field | Specify the name of the field in the OpenSearch document where the embeddings are stored. This field needs to be a 'knn_vector' type. The default value is `vector_embedding`. |
| OpenSearch Host URL | Specify the URL of the destination OpenSearch instance. |
| OpenSearch Index | Specify the name of the destination OpenSearch index. |
| OpenSearch Password | Specify the password to use for authenticating to the OpenSearch server. |
| OpenSearch Username | Specify the username to use for authenticating to the OpenSearch server. |
| Source ADLS File System | Specify the name of the source ADLS file system also known as container. |
| Source ADLS Path | Specify the path within the source container where you want to read from. |
| Source ADLS Storage Account | Specify the source ADLS storage account name. |
| Source ADLS Storage Account Key | Specify the source ADLS storage account key. |
