ADLS to Pinecone required parameters
When deploying the ADLS to Pinecone ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| OpenAI API Key | Specify the API key used to authenticate to OpenAI. |
| OpenAI Model Name | Specify the OpenAI model name to use for embedding the data.
The default model is 'text-embedding-ada-002'. |
| Pinecone API Key | Specify the API key used to authenticate to Pinecone. |
| Pinecone Environment | Specify the name of the Pinecone environment. Pinecone no longer requires the environment to connect, but you still need to provide a value for this parameter for the deployment to succeed as the related property in the Pinecone processor is required. |
| Pinecone Index | Specify the name of the Pinecone index. To ensure correct functionality of this ReadyFlow, make sure your Pinecone index has been created with the same dimension as the 'text-embedding-ada-002' model (1536). |
| Source ADLS File System | Specify the name of the source ADLS file system also known as container. |
| Source ADLS Path | Specify the path within the source container where you want to read from. |
| Source ADLS Storage Account | Specify the source ADLS storage account name. |
| Source ADLS Storage Account Key | Specify the source ADLS storage account key. |
