ADLS to Qdrant required parameters
When deploying the ADLS to Qdrant ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
Table 1. ADLS to Qdrant ReadyFlow configuration parameters
Parameter Name Description
OpenAI API Key Specify the API key used to authenticate to OpenAI.
OpenAI Model Name Specify the OpenAI model name to use for embedding the data.
The default model is 'text-embedding-ada-002'.
Qdrant API Key Specify the API key used to authenticate to Qdrant.
Qdrant Collection Specify the name of the destination Qdrant collection.
Qdrant URL Specify the URL of the destination Qdrant instance.
Source ADLS File System Specify the name of the source ADLS file system also known as container.
Source ADLS Path Specify the path within the source container where you want to read from.
Source ADLS Storage Account Specify the source ADLS storage account name.
Source ADLS Storage Account Key Specify the source ADLS storage account key.
