ADLS to S3 required parameters
When deploying the ADLS to S3 ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
Table 1. ADLS to S3 ReadyFlow configuration parameters
Parameter Name Description
Destination S3 Bucket Specify the name of the destination S3 bucket you want to write to.
Destination S3 Path Specify the path within the destination bucket where you want to write to.
Destination S3 Region Specify the AWS region in which your destination bucket was created.
Destination S3 Secret Access Key Specify the destination S3 secret access key.
Destination S3 Secret Access Key ID Specify the destination S3 access key ID.
Source ADLS File System Specify the name of the source ADLS file system also known as container.
Source ADLS Path Specify the path within the source container where you want to read from.
Source ADLS Storage Account Specify the source ADLS storage account name.
Source ADLS Storage Account Key Specify the source ADLS storage account key.
