Airtable to ADLS required parameters
When deploying the Airtable to ADLS ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| Airtable Base ID | Specify the ID of the Airtable base to be queried. |
| Airtable Field Names | Specify the field names requested from the Airtable table to be queried as a comma separated list. |
| Airtable Personal Access Token | Specify your Airtable personal access token. |
| Airtable Table ID or Name | Specify the ID or name of the Airtable table to be queried. |
| CSV Delimiter | If your output data is CSV, specify the delimiter here. The default value is
| Data Output Format | Specify the desired format for your output data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow. |
| Destination ADLS File System | Specify the name of the destination ADLS file system also known as container. |
| Destination ADLS Path | Specify the path within the destination container where you want to write to. |
| Destination ADLS Storage Account Key | Specify the destination ADLS storage account key. |
| Destination ADLS Storage Account Name | Specify the destination ADLS storage account name. |
| Include Metadata | Specify whether to return Airtable fields only or include metadata fields in the
result. Set to "true" to include metadata fields in the result. Airtable fields will be stored in the 'fields' field. Set to "false" to include only Airtable fields in the result. The default value is "true". |
