Airtable to S3 required parameters
When deploying the Airtable to S3 ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| Airtable Base ID | Specify the ID of the Airtable base to be queried. |
| Airtable Field Names | Specify the field names requested from the Airtable table to be queried as a comma separated list. |
| Airtable Personal Access Token | Specify your Airtable personal access token. |
| Airtable Table ID or Name | Specify the ID or name of the Airtable table to be queried. |
| AWS Access Key ID | Specify the AWS access key ID. |
| AWS Secret Access Key | Specify the AWS secret access key. |
| CSV Delimiter | If your output data is CSV, specify the delimiter here. The default value is
| Data Output Format | Specify the desired format for your output data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow. |
| Destination S3 Bucket | Specify the name of the destination S3 bucket you want to write to. |
| Destination S3 Path | Specify the path within the destination bucket where you want to write to. |
| Destination S3 Region | Specify the AWS region in which your destination bucket was created. |
| Include Metadata | Specify whether to return Airtable fields only or include metadata fields in the
result. Set to "true" to include metadata fields in the result. Airtable fields will be stored in the 'fields' field. Set to "false" to include only Airtable fields in the result. The default value is "true". |
