ReadyFlow overview: Box to ADLS
You can use the Box to ADLS ReadyFlow to consume files from a Box folder and write them to a destination ADLS location.
This ReadyFlow consumes files from a Box folder and writes them to an ADLS location. For the source, specify the Box app credentials (account ID, config file) and the Box folder ID. You can choose whether to include subfolder files. For the destination, specify the ADLS storage location and path. The ReadyFlow polls the Box folder for new files (it performs a listing periodically). Failed ADLS write operations are retried automatically to handle transient issues. Define a KPI on the failure_WriteToADLS connection to monitor failed write operations.
Box to ADLS ReadyFlow details
Source Box
Source Format Any
Destination External ADLS
Destination Format Same as source
