Box to ADLS required parameters
When deploying the Box to ADLS ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
Table 1. Box to ADLS ReadyFlow configuration parameters
Parameter Name Description
Box Account ID Specify your Box Account ID.
Box App Config File Upload the Box App config file in JSON format.
Box Folder ID Specify the ID of the Box folder you want to read from.
Destination ADLS File System Specify the name of the destination ADLS file system also known as container.
Destination ADLS Path Specify the path within the destination container where you want to write to.
Destination ADLS Storage Account Key Specify the destination ADLS storage account key.
Destination ADLS Storage Account Name Specify the destination ADLS storage account name.
Include Subfolder Files Specify whether to include list of files from subfolders. Set to "true" to include files from subfolders. Set to "false" to only list files from the specified Box folder.
