ReadyFlow overview: Box to S3
You can use the Box to S3 ReadyFlow to consume files from a Box folder and write them to a destination S3 location.
This ReadyFlow consumes files from a Box folder and writes them to an S3 location. For the source, specify the Box app credentials (account ID, config file) and the Box folder ID. You can choose whether to include subfolder files. For the destination, specify the S3 storage location and path. The ReadyFlow polls the Box folder for new files (it performs a listing periodically). Failed S3 write operations are retried automatically to handle transient issues. Define a KPI on the failure_WriteToS3 connection to monitor failed write operations.
Box to S3 ReadyFlow details
Source Box
Source Format Any
Destination External Amazon S3
Destination Format Same as source
