Dropbox to ADLS required parameters
When deploying the Dropbox to ADLS ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
Table 1. Dropbox to ADLS ReadyFlow configuration parameters
Parameter Name Description
Destination ADLS File System Specify the name of the destination ADLS file system also known as container.
Destination ADLS Path Specify the path within the destination container where you want to write to.
Destination ADLS Storage Account Key Specify the destination ADLS storage account key.
Destination ADLS Storage Account Name Specify the destination ADLS storage account name.
Dropbox App Access Token Specify your Dropbox App access token.
Dropbox App Key Specify your Dropbox App key.
Dropbox App Refresh Token Specify your Dropbox App refresh token.
Dropbox App Secret Specify your Dropbox App secret.
Dropbox Folder ID or Path Specify the identifier or path of the Dropbox folder you want to read from.
Folder should match the following regular expression pattern: /.|id:.
Example for folder identifier: id:odTlUvbpIEAAAAAAAAAGGQ
Example for folder path: /Folder1/Folder2
Include Subfolder Files Specify whether to include list of files from subfolders. Set to "true" to include files from subfolders. Set to "false" to only list files from the specified Dropbox folder. The default value is "true".
