Dropbox to S3 required parameters
When deploying the Dropbox to S3 ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
Table 1. Dropbox to S3 ReadyFlow configuration parameters
Parameter Name Description
AWS Access Key ID Specify the AWS access key ID.
AWS Secret Access Key Specify the AWS secret access key.
Destination S3 Bucket Specify the name of the destination S3 bucket you want to write to.
Destination S3 Path Specify the path within the destination bucket where you want to write to.
Destination S3 Region Specify the AWS region in which your destination bucket was created.
Dropbox App Access Token Specify your Dropbox App access token.
Dropbox App Key Specify your Dropbox App key.
Dropbox App Refresh Token Specify your Dropbox App refresh token.
Dropbox App Secret Specify your Dropbox App secret.
Dropbox Folder ID or Path Specify the identifier or path of the Dropbox folder you want to read from.
Folder should match the following regular expression pattern: /.|id:.
Example for folder identifier: id:odTlUvbpIEAAAAAAAAAGGQ
Example for folder path: /Folder1/Folder2
Include Subfolder Files Specify whether to include list of files from subfolders. Set to "true" to include files from subfolders. Set to "false" to only list files from the specified Dropbox folder. The default value is "true".
