ReadyFlow overview: Azure Event Hub to ADLS
You can use the Azure Event Hub to ADLS ReadyFlow to consume JSON, CSV, or Avro events from Azure Event Hub and write JSON, CSV, or Avro files to ADLS.
This ReadyFlow consumes JSON, CSV or Avro data from a source Azure Event Hub Namespace and merges the events into JSON, CSV or Avro files before writing the data to ADLS. You can filter events by specifying a SQL query in the Filter Rule parameter. The flow writes out a file every time its size has either reached 100MB or five minutes have passed. Files can reach a maximum size of 1GB. You can specify the Event Hub Namespace you want to read from as well as the target ADLS data container and path. Failed ADLS write operations are retried automatically to handle transient issues. Define a KPI on the failure_WriteToADLS connection to monitor failed write operations.
Azure Event Hub to ADLS ReadyFlow details
Source Azure Event Hub Namespace
Source Format JSON, CSV, Avro
Destination External ADLS
Destination Format JSON, CSV, Avro
