HubSpot to S3 required parameters
When deploying the HubSpot to S3 ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| AWS Access Key ID | Specify the AWS access key ID. |
| AWS Secret Access Key | Specify the AWS secret access key. |
| CSV Delimiter | If your output data is CSV, specify the delimiter here. The default value is
| Data Output Format | Specify the desired format for your output data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow. |
| Destination S3 Bucket | Specify the name of the destination S3 bucket you want to write to. |
| Destination S3 Path | Specify the path within the destination bucket where you want to write to. |
| Destination S3 Region | Specify the AWS region in which your destination bucket was created. |
| HubSpot Access Token | Specify the HubSpot access token to authenticate requests. |
| HubSpot Object Type | Specify the HubSpot object type to request. An Object Type is prefixed with
/crm/v3/objects/ where the following suffixes are supported:
| HubSpot Result Limit | Specify the maximum number of results returned by the HubSpot processor (max. 100). |
| Include Metadata | Specify whether to return HubSpot fields only or include metadata fields in the
result. Set to "true" to include metadata fields in the result. HubSpot fields will be stored in the 'properties' field. Set to "false" to include only HubSpot fields in the result. The default value is "true". |
| Incremental Delay | Specify a value for this HubSpot processor property to avoid missing objects when the
clock of your local machines and HubSpot servers' clock are not in sync and to protect against
HubSpot's mechanism that changes last updated timestamps after object creation. This property is
only used if "Incremental Loading" is set to "true". The default value is "30 sec". |
| Incremental Loading | Specify a value for this HubSpot processor property to decide whether to load queried
objects incrementally. Set to "true" to query each object exactly once. Set to "false" to query
each objects at least once. The default value is "true". |
